turbodude
- 290
- 10
- Jul 17, 2011
Olympia,
Washington
Update: Video posted!!!!!
Hello, maybe someone can help before i start tearing things apart under the hood to try and figure this thing out blindly. Here is the situation:
Whenever i start my GS-t in the mornings or after it has been sitting for an extended period of time it makes a very audible vibrating, rattling almost a grinding type sound for about 1-2 seconds at the exact point where the engine actually turns over before going into normal idle. Again, the sound is not there when it's actually cranking or idling at normal RPM, but once the engine catches and officially turns over, for 1-2 seconds i get that hideous rattle/grind sound.
It's not the starter or anything to do with that as i know what an un-engaged/stuck starter sounds like and it is a much different sound.
When i start my car after putting gas or making a pit stop at the store there is absolutely no sound or noise at all and sound completely normal. Just when the car is cold.
My best guess would be perhaps the tensioner pulley or something that is being ran off the belts? any help would be greatly appreciated. Thanks!
http://www.youtube.com/watch?v=T--pKLNBYFI
It's not the starter or anything to do with that as i know what an un-engaged/stuck starter sounds like and it is a much different sound.When i start my car after putting gas or making a pit stop at the store there is absolutely no sound or noise at all and sound completely normal. Just when the car is cold.
!! I needed that!
