Rattle from oil pump?
Justin52587
Jan 16, 2012
Pevely, Missouri
Ok guys got everything fixed with the fuel in oil problem drove great for about a week then today was driving to lunch and when i hit about 3300 rpms or so i get i dont know if i wana call it a rattle or not almost like a shudder i guess i could say but i can hear it so i put a scope up to the oil pump and it sounds like its coming from the pump or shaft maybe??? anyone ever heard of this and where can i find a shaft\bearings if thats the problem?? help ### :banghead:
i checked to see if the nut was loose its not i tried pulling on the crank didnt have any play so im thinking bs delete will fix it if so can someone post a quality kit dont want ebay garbage i want to delete front and rear ###
Go to extreme psi and get the stubby shaft and plug. You can just rotate the bearings in the front shaft bores to block off the oil holes.
