Random Missfire
Shipe12
43
Oct 11, 2008
Sinking Spring, Pennsylvania
Hi i have a 99 GST and i have a random multiple missfire code i have replaced everything but the coil packs. In the diagnostics it says you could have a vaccum leak thats causing the missfire. Could a missfire cause the car to run at a lower In Hg or do i have a vaccum leak for sure, because my car idles at 10-15 In hg. thanks for any help.
Man, I don't remember what idle vacuum should be... but for some reason, I think it should be about 18 with stock cams. So a vacuum leak could be the culprit. Also, your CAM sensor could be shot.
