1G Radiator fan switch connector wire order
I21chardh
34
14
Oct 10, 2022
Denver, Colorado
Redoing my radiator fan switch connector and can’t remember which side the green/yellow and green/black wires go. Pretty sure it was green yellow was on right side of connector if clip of connector is on bottom but wanted to be sure before soldering
The diagram shows the connector as viewed from the backside or from the harness side, and the latching mechanism oriented at the top.
Pin 1 is green with yellow.
Pin 2 is black with green.
So from the front face as you have pictured, green with yellow to the right-side position, black with green to the left.
Thank you!
