Quick Timing belt question about running without an upper cover
big green
644
Nov 19, 2002
Lake Orion, Michigan
Is it ok to drive the car with out the upper timing belt cover on? I see allot of people do it it. I lost mine and wont have a new one for awhile. I'm worried a stone or somthing might get caught. :confused:
Defiant said:
That's exactly what you should worry about. If your luck holds out, it won't otherwise hurt anything. But it takes a rock about the size of a BB.
Thats how I feel also but I have had another dsmer tell me that wont happen since the hood sits so close to the timing gears and belt. :rolleyes:
I personally wouldnt drive my car without it. Ferrea 1mm os stainless valves are quite expensive. I dont want to have to buy another set.
It will run just fine; the accy belts dont have any protection and how often does debris tear them??
On the other hand, a broken accy belt generally dosnt take anything of consequence out with it, and the timing belt breaking will at the minimum bend a couple of valves.
Mine has a cover, and it will stay on....I guess it comes to how lucky you are feeling...
