upper timing belt cover hitting belt
coryf1233
246
Nov 6, 2007
hanover, Pennsylvania
I have searched and found stories of timing belts hitting the cover, but no help on what to do..i can see a faint mark on the belt on where its hitting, i just noticed it and then line is pretty faint..so im assuming it just started..what sho0uld i do
really the only thing you can do, is replace the cover because yours has probably been mishapen and or warped due to heat.
it can be a pain to do this because it involves taking the pulleys off the motor, and you could accidentally mistime it so you'd have to be very careful. (your motor isn't a "interference motor" so you don't need to worry about bending valves or anything if you mistime it.
personally i think you should do what i did and let it be until it falls off or starts causing issues, and then replace it.. that's what i did with mine and it never damaged the motor or caused any problems
if you really want to replace it check these sites
thedsmgraveyard.com
or (the obvious)
Ebay.com
it will probably cost around 20-40$ depending on shipping.
EDIT: wait is this the front or back cover ?(front will be plastic, and back will be metal.)
WTF Lots of misinformation here. And our motors ARE interference motors which is why proper timing is critical. To remove the upper timing cover on a turbo motor you only have to remove a few bolts.
OP, how do you know that the belt is hitting the upper cover? If there is a wear mark on the timing belt and you're not certain where it's rubbing it's probably from a couple of the oil pan bolts. 2 of the bolts are shorter than the others and they must be placed one under the crank sprocket and the other under the oil pump gear.
Well if the cover is warped or otherwise damaged causing it to contact the belt then you need to replace the cover. Also make sure your timing belt is not loose.
If you run the motor with the cover off does the noise go away? Are your cam gears wobbly?
What type of noise?
its just a rubbing noise, you can tell something moving is moving against something stationary, when i put the timing cover on it almost seems like it doesnt fit right,, kinda tight and too close
If the noise goes away when you remove the cover then I guess it's safe to say that is the problem. Sounds like you need to replace it.
Run the car with the cover off at idle and make sure that the belt is not trying to walk off the cam gears. It doesn't sound like this is a problem for you, but it's worth taking the 5 minutes to make sure.
As others have posted, check your cam gears to make sure they're not wobbly, then invest in a new timing belt cover. You could try a clear timing belt cover - they look bad-ass if you have adjustable cam gears to show off!
Loud belt squeaking at startup is usually indicative of a loose belt. It's doubtful that a chipped crank pulley would cause that. Tighten up the belt at the alternator. Though it might feel tight, it's probably not tight enough.
