quick safc question
one_bad_7
65
Oct 5, 2008
lake in the hills, Illinois
I need some help with my safc real quick
if the safc says my idle is 600 im actually at 1200 the idle on safc is alsways half...
is this something wrong with install or in the settings. thanks alot in advance
IIRC if you have it installed on the 1g, you will need to change your car's number of cylinders on the safc to 2 to correct it
yes i saw that way but as i learned isnt the "correct" way. it turns out to be in vfaq. were you wire it into the wire harness. thanks alot though
thasnk Jeff
