Quick question: would wrong spark plug gap cause a no start?
solisjulian
82
Jan 5, 2013
wooddale, Illinois
Would wrong spark plug gap cause a car not to start?
i have a N/A talon and the gap it at .35 and its supposto be at .44 would that cause the car not to start?
it fires up almost but dosent could that be the problem?
yeah i did i tested everything yesterday and everything came out okay
so you dont think the plug gap could cause this? it wants to start but it dosent completly
im pretty stumped on the problem it only fires up with starting fluid
thats the only way i can start it on a cold start , afterwards it drives fine
only hard to start on cold starts like it wants to fire but it dosent completly untill i put starting fluid
So you have fuel, spark you checked for compression, the battery, the coolant temp sensor, the starter, is cold, the power transistor unit, loose or frayed wires at the coolant temp sensor on the throttle body, any of these things can cause a no start. Fuel pump relay is tested, the mpi fuse, ignition fuse on the battery location is good. Correct So many variables, pick one then rule them out as you go. It may take time.
sorry i was at school and didnt reply i really appreciate your feed back, i did find something weird going on my CTS only reads 3 volts with the key on would could be the cause and no ressitance.
never mind it read 2.77 ohm and its 3 degrees out its pretty off
what could be the cause?
  • Wanted 1g Headliner
    ISO 1G Headliner with sunroof provision
    • ItsTwan309
  • Wanted 2g Rear Evo8/9 calipers
    Looking for a clean pair of evo 8/9 rear calipers.
    • Schinjon
  • For sale 2g turbo ecu’s
    $120 each +shipping&pp fees.
    • Fully built dsm
  • For sale 650cc injectors
    Fic 650cc injectors $70 plus shipping and pp fees
    • Fully built dsm
  • For sale 2g dsm link v3
    Hello, It works great I just took it off because I’m selling the car stock and don’t have any...
    • Fully built dsm
