quick oil squirter issue (Fix it yourself'ers ITT)
FastGS-T
295
8
Oct 20, 2005
Arab, Alabama
Alright so I am installing my oil squirters into this new block that I just got back from the machine shop, and the #2 squirter bolt breaks off into the block and I had to ease it out. None of the other bolts would tighten all the way up in that cylinder but the bolts worked fine in cylinders 1, 3 & 4.
The rotating assembly is already in the short block. Should I try chasing the hole or just put loctite on it and run it down as tight as it gets before it breaks loose?
