Oil Squirter problem
ssmokeyy
Jun 5, 2009
spokane, Washington
I got the motor back from the machine shop and they found a crack line in the stock 1g oil squirter. The customer just got his 2g with this motor in it. I found on extreme psi they sell both 92-94 and 94-95 and i was wondering how would i know which one i need they both look the same to me. Is it ok to just change one or should i replace all 4.
if just the squirters cracked it might be best to just replace all 4. don't forget the new oem crush washers that go with them.
the 92-94 is 6 bolt's, and 94-95 is 7 bolt.
Wrong
90-92 is 6 bolt, 93-94 is 7 bolt. If this a 6 bolt use the 6 bolt part number 7 bolt you have either the 93-94 style which look similar to 6 bolt or you have the 95 up 7 bolt style which are for 2g only.
