420A Questions regarding clutch and power steering pump replacement
Lacross
Nov 16, 2012
sayreville, New Jersey
Hi all, i'm new to the forum here, ive come in hopes of some solid answers as googling doesnt do a good job for this car.
My car is a 98 eclipse with the 420a
Problem A: it needs a new clutch, i know these take a modular clutch, but whats a good oem replacement?
Problem B: Im not sure if i need a new power steering pump or to just remove the pulley and put it back on. The power steering pulley is shaking and knicking a nut near it creating an annoying "chirping" sound.
Is there a video anywhere on how to replace a power steering pump on an Eclipse?
Also, i guess ill put this all in one thread. I have a rough idle, sometimes my engine will almost shut off and then it will shoot up to 2k rpm, normally it surges between 600-1500 and its quite annoying.
Also my OBDII connector doesnt work WTF!!
Thanks in advance,
LaCross
Its pretty bad, surging between 500ish-1500 is pretty abnoxious, and then the car will almost shut off sometimes
Appreciate the help guys,
Now the isc , this is connected to the throttle body? how exactly do i go about resetting it? Any pictures relating to it?
Thanks
