Spyder Questions and suggestions please.
tonydl
May 3, 2021
Prineville, Oregon
So i have a 97 eclipse spyder gst and lately have had over heating issues,i had to replace my radiator,i did my timing and water pump also,i bled the system the best you can,my guage reads correctly but ill climb pretty fast if i dont have my heater on,im not sure what it is exactly but the radiator is made for the 2.0 turbo dohc,ive done my thermostat too and still cant seem to keep it cool any suggestions?also was curious im running the stock toyo intercooler could i maybe need a new one?the only upgrades would be my camshafts and lifters,but allot of newer parts on the car already.soooo just needing some input on some things and maybe just ideas of what i could do or should do?
Sounds like you got air trapped in the system still. Gotta burp it. Keep squeezing the lower radiator hose with the cap off until u don’t see any more air bubbles coming out
Ok ill try that again for sure
Several things...
Air trapped in system.
Defective thermostat/water pump even tho they are new
Missing heat shields
Fans not functioning properly
You wouldve seen it working on the radiator but has intense heat warped/disfigured your fans reducing the flow?
Front mount IC blocking the flow to the radiator?
or perhaps several of these issues all contributing to the overall issue?
Just for more information, do you notice it climbing just by idling? Does the temp start to drop if you start driving?
So im pretty sure it was air in the system i ended up just drowning it with water while squeezing the bottom hose repeatedly and its not over heating now,funny thing is now im having an issue with my vac,i droped 5 pounds in vac randomly and im taking out plugs and checking wires as we speak,also clutch is soft after changing fluids,i did 2 ways,first push clutch down have someone hold twist screw then close screw pull peddle up,the other way i did it is similar but at the end i left the pedal down and manual pushed the slave rod towards the slave held it in place and put the bleed screw back in im not sure if im just doing it wrong or what but todays been the day for f*** ups LOL.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
