questions about buying new oil pump (front case)
houstonECLIPSE
53
Jan 27, 2003
Houston, Texas
in the CAPS program it lists two part numbers for the 6 bolt 4g63 for the front case. with one should i go with? md129347 or md175762?
are the parts numbered 04015 and 04016 included when i buy the front case? theres a line connecting them to inside the box numbered 0200A but i just want to make sure of what i need to buy. thank you.
lupe
SBR has it listed on their site as md125938. That's for the 7 bolt oil pump with gears. They list it for 290 and a topline replacement for 180 if you don't need the OEM piece of mind as much as just a replacement.
yeah i've been doing some reading and i have decided to go oem for the oil pump. i'm just trying to figure out what and what doesn't come with the front case when you but it from the dealer as far as gaskets, seals, oil pump gears, etc.
lupe
