Question about my water pipes with 1g2gswap
95EclipseGST
406
Mar 1, 2002
Kansas City, Missouri
This part of the water pipe thats in the pic goes to the turbo on one of those fittings with a hole right?Im gonna have to make something go from this part of the water pipe to the back of the turbo right? There are 2 coolant lines on the turbo,one on the back that this goes to "i think" and then where on the water pipes does the front cooling line go to? This is an EVO3 turbo and a complete 1g engine with 1g water pipes if that helps.I have read all the magnus and roadrace stuff and cant take it anymore. OMG Thanks
-The coolant line that goes to the front is "U" shape, bolt to that extension on your 2nd photo.
I am not sure about the rear one, I think it goes to a rubber hose on the left side of the block/water-fill area. The front water line: connect it to the water line in the picture there, then connect it to the front of the turbo via banjo bolt. (I have never done this on a 1G, only seen pictures, and 1 14B removal). But I am pretty sure I'm correct.
-#33 goes to #34 from mine post above, it goes to a rubber hose at the upper most outlet of the thermostat neck.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
  • Wanted wtb black 2g dashboard
    Looking to buy a 2g black dashboard. Located in southern california but willing to travel.
    • randizzle420
