Question about MSD DIS2 ignition
silvergstguy
Mar 31, 2004
San Antonio, Texas
I'm starting to build up my eclipse... gonna stay on stock motor, ultimately going for 450whp on race gas, and 350 or so on pump... I traded an old cell phone for an msd dis2 ignition... do i need it? or should i sell it... I know that the stock ignition is good for what i want... but would this help me or just make it more complication.... THanks in advance...
Also its a 6bolt in a 2g running dsmlink
Well If I where you I would keep it and install it . Just read up before you do the install . You are going to need a msd tach adapter. Oh , many people will say that the stock ignition is fine but if you go to www.Taboospeedshop.com They will tell you it is good to around 300hp . Msd :thumb:
I dont believe a tach adapter is needed for the second gereation cars, and there is a member on this forum that has run 10s on a stock ignition.
i have the tach adapter.... i'll probably hold on to it for a while and if i have no problems then get rid of it...
thanks for the help though
You don't need it but is a good ignition upgrade. You should be able to run a higher plug gap without blowing it out. I think most people use it mostly for the 2-step for launching and no lift to shift.
I never was able to run the big plug gap that people kept talking about. The car did run cleaner low end with the MSD box and the 2 step was very nice. I have had my MSD off for a year and I havent had any ignition issues.
