question about GM MAFT... size?
JiveMasterT
1,848
9
Jan 3, 2004
Chest of Westerson, New York
I want to order a MAFT for my 3.5" GM MAF and I was wondering if, later on down the road I wanted to change over to a 3" GM MAF if I would also have to get a different MAFT. I was able to get a 3.5" MAF for $50, so I took it, but I'm concerned that it is too big, but I figured I might as well use it. Any information would be appriciated. thanks.
For the 3.5" GM MAF you just change one of the settings on the MAFT. You will also need a larger coupler. Otherwise that, it works fine :)
Curiosity speaking, what's the advantage to going with a 3.5" GM MAS, as opposed to the 3"? A more accurate reading since the air would technically flow through the larger expansion slower, or what?
don't think there's any real advantage other than the fact that I can get one online for $100 or I can get one off my friend's transam for $50.
There is a dipswitch inside the MAFT that allows you to select the 3 inch or 3.5 inch gm mas. Some people say that there cars run better if the dip switch is on the 3.5 inch gm mas while they are running the 3 inch.
Only con i have heard about the 3.5 in blow thru is the expansion and reduction at the maf would disrupt air flow alot more.
