Question about Big28 install
big green
644
Nov 19, 2002
Lake Orion, Michigan
I finally got my ported FP big 28 today. I'm going to do the install in a few days, but I forgot to get new gaskets. What gaskets should be replaced when installing this turbo?
If your gaskets aren't cracked or bent, You can reuse them. But its always good to use new ones. If you do want to replace them, get a turbo to manifold gasket, o2 housing to turbo gasket and a downpipe gasket. All washers can be reused if you want but they're cheap so I'd replace them. 4 cooper washers for the 2 water lines. If your using a SS feed line, use crushed washers for that too.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
