leakyfaucet
- 818
- 2
- May 29, 2004
cincinnati,
Vermont
Hello, I'm on a serious budget with my 91 Tsi. Currently, it as a mystery fuel pump in it. I'm assuming its a walbro 190 or 255 because it whines so loudly. It has not been rewired, however. The car had the stock fuel pump sitting in the hatch when I got it.
My car has been getting less than great gas mileage- usually about 20mpg and I drive conservatively. Boost also has been coming on rather slow. I'm considering the possibility of the aftermarket fuel pump overrunning the FPR and causing the car to run rich, so I want to put the stocker back in.
I've never swapped fuel pumps before, but from what I understand, the biggest problem is getting the old fittings apart, which shouldn't be a problem since it has been done recently.
Are there any new parts I will need to put my stocker back in? Or will everything I need already be on the aftermarket pump that's inside of it?
I don't plan on doing any tuning mods so the factory fuel cut should save my ass if I decide to push the motor too far, right?
