Pulling a Fuses
If you pull the MPI fuse the car won't start at all since the MPI fuse powers the ECU.
If you don't want any fuel, disconnect the fuel pump power or unhook the injectors from the injector resistor.
Well the funny thing is, the car still turns with the stater. I dont know if the ecu is still working or not. After disconnecting the MPI fuses the car turned with the start but i am concerned if the pump/injectors is still delivering fuels.
So MPI did shut the pump down im guessing? and for the record what plugs on the fuel pump is the power? i need to disconnected for safety.
Indirectly. Pulling the MPI fuse disabled the ECU so that the injectors never fired and kept the ECU from turning the fuel pump on but I don't remember if all 2G's don't have the second input to the MPI relay that activates the pump while cranking.
