PTE Turbo help
gsxeclipsed
367
Sep 24, 2004
Greenwood, Indiana
Hey guys ive been looking and reading and researching im going to be running the punishment racing t3 manifold with the 38mm external gate on the collector. I was looking at maperformance at the hybrid turbos something like the sc44 im looking for around 500 awhp. i am planning on running dsmlink, with a walbro 255, AFPR, not sure on injector size? does anyone know about this turbo or about the injectors i need to run? im going to be running a built block with scat or eagle rods and weisco pistons. BC 272's and ti springs and retainers, with 1mm oversizeds valves. a JMF intake and some front mount not for sure on that yet either. also gm maf and if i need any other mods please let me know.
Thanks Ben
Which PTE turbo are you going to be running? I would personally go for 1000cc injectors if you're running DSMLink. I'm using 880cc right now, but only looking to make 400-450 whp.
I wouldn't bother with that turbo, get a 50 trim or GT30 instead.
I would stay away from that hybrid turbo also. I would recommend an S256 extended tip turbo. It will spool up at least 500rpm sooner than the BB 50 trim and outflow it by about 5-6 lbs/min on the top end. It is very close to the price of the BB 50 trim also. I have supplied both to my customers I just think the performance of the BW extended tips is hard to beat. PM me if you want more info or a price on either.
Wayne
