turbo help-- PTE TURBO SC6176S
skate enjoi
Banned Member
54
Sep 29, 2004
niles, Michigan
alright ive tried searching for anyone thats used this turbo but i get nothing. its PTE TURBO SC6176S with the s cover 4" inlet and 2.5" outlet .. t-3 .82 a/r, 4 bolt 2.5" discharge ... im looking to see when people are getting this to spool? if they like it or have any complaints about it... it will be going on a 2.3 stroker by the way, thanks
I have the t3 sc6152, .63a/r turbine housing with a stage 5 turbine wheel. I hit full boost at just over 5200rpm, full boost being 18psi. Your 2.3l stroker should have no problem spooling up the sc6176 because of the increased displacement. The bigger turbine housing and wheel will work well with that engine. What do you plan to shift at or rev to? I would guess that with the bigger turbine housing and the 76 turbine wheel, you should still get full boost at were I'm getting it or a bit lower. Either way, it'll haul ass.
later
hey thanks for the reply... i was hoping to get full boost by about 5000 or so, but ill be running like 25-30psi.. i plan on revving to 8k on the street and 8.5k on the track which will be very rarely...
