PTE SCM turbo oil return
my98GST
1,045
21
Jun 1, 2005
Cleveland, Tennessee
I have an EXTREMELY bad oil leak coming from the ExtremePSI.com install kit. it is a -an fitting, a tube, and another fitting and it is a push on. The oil is leaking out of the push on through the front of the fitting that screws on to the male threads on the fittings of the male (mounted to oil pan) What can I do for another oil return? Surely theres another option?
Same thig happened to me I did a temporary fix and drained the oil let it dry and rtv'd the crap. I believe FP makes very good oil return lines if I have any more leaking problems I'll go to that. Also make sure it's installed correctly. As in the ss line snug and seated in the fitting.
Im glad to hear this I was going to order that set up this week. If you find something that solves the problem or is just a better product share the info.
Okay first off. If you laugh i'm going to kick you in the nuts...... :D
I made a stupid and forgot to tighten one of the allen bolts that holds the fitting on the oil pan so that was the "main" cause of hte big leak. Second I reteflon taped the threads and torqued the living shit piss out of the female fitting and it seems to have done a lot better but still drips a tiny bit.. I ordered a new fitting to see if one of the threads were boogered or what not.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
