e85_4g63
- 1,492
- 15
- Nov 17, 2008
Manheim,
Pennsylvania
Any update's with your 6262's guys?
It's been 2 weeks since the last post.. Any progress guys?
I have a dual ceramic ball bearing 6262SP turbo in T3 0.82 A/R hot side. At 30psi a see around 60lb/min. In couple of weeks I will be dyno my car at different boost settings up to 40psi. Dyno numbers will give me a better idea about airflow. With speed density it can be tricky to get accurate airflow numbers, with MAF it would be more accurate. I m running on speed density. 30psi I see around 5k rpm.
PTE tech support claim this turbo is capable of flowing 70+lb/min. Also, this turbo is fully rebuildable meaning pte can replace parts within the center cartridge which should cost a lot less than replacing a Garrett center cartridge.
Usually when there is no response nine times out of ten this is the results of dissapointments.
Been meaning to up the boost and see what more I can push out. Just popped an intercooler pipe two nights ago and fixed that.
)Been 2 mores weeks, anything new yet... ? ()
I actually just filled the car up on some old 93 octane. I wanted to drive it around a little more lately and the E85 was getting annoying. I'll probably be on pump for a few tanks. I'm going to try to dial in the car and do some tuning tonight so I should have some pump gas numbers for you.
im running a 6262 .83 hotside t3 turbo and have made 539hp and 444lbs of torque at 30psi on 93oct. love this turbo and spools just fine for its size.
^^^ Looks good Luke!! Nice airflow numbers, she's gotta be putting down some good power with those #'s
keltalon Have you made it to dyno yet? I am curious to see what kind of numbers you are making with the 60lbs/min. Can you post a WOT log. Thanks:cool:[/QUOTE said:Sorry, i did not dyno yet. Car was in a garage for the last two month waiting for race transmission. Now I got Shep stage4 transmission and a new South Bend clutch kit. Hoping to break-in transmission within next couple of weeks and then I will take it to a dyno. Once I get the numbers, I will update this post.
(bolt on housing guys: How are you running your waste gate setups (off the o2 housing or manifold))?I know a post a lot in reguards to the 6262 turbo specifically, so... any updates?(bolt on housing guys: How are you running your waste gate setups (off the o2 housing or manifold))?
Been a couple more months.. updates?
46lbs/min seems piss poor for a modern 62mm turbo at 25psi. Your gonna make about 375whp on 93 with that.
