mnetwork
- 1,017
- 2
- Feb 25, 2006
New Milford,
New Jersey
I am now running a bolton PTE 6262SP turbo. I did a few pulls for the first time tonight, didn't touch fuel or timing yet as I was just playing with boost. I see that the turbo doesn't really shine until 25+ psi. There is a considerable jump in airflow just from 23 to 25psi. I ended up running around 26psi. I was flowing around 46lbs, I wanted to know what kind of airflow others have seen with this turbo, I just want to know what I should be seeing. Also, how high are people able to boost on this turbo on 93 octane. So far 26psi doesn't seem to yield too much knock at all. I do plan on upping boost and running E85 after I get a good pump gas tune down.
The turbo is definately stronger than my 16g was at 26psi and spool is decent, I see full spool around 4600.
. On a serious note, what options did you get with the PTE (6262, SP cover, T3 .82 A/R)?
