- Thread starter
- #51
mnetwork
- 1,017
- 2
- Feb 25, 2006
New Milford,
New Jersey
I was moving 46lbs/min on a HX35 in a 12cm housing at 25psi on stock cams.
Ditch that bolt on housing.
Swapping out the housing would mean new housing, new manifold, new o2 housing and new/modified downpipe. I'm not convinced that I would be getting the airflow numbers that I should be just by doing that, so I am reluctant to do this. I have never tried adjusting my cams, but I doubt that I could make a good enough change with the adjustment alone.
at that same boost i have plenty of fuel with the smaller turbine because it's just not fl0owing the air out to let enough in to make good power.. the bolt on housings have always beena restriction and on a turbo this size that's like breathing through a virginia slim ciggarette for your air to run a marathon
