PTE 1200 injectors seats/seals
IrishBeatdown
585
5
Feb 3, 2012
Tucson, Arizona
I've had a hell of a time trying to find a new oring set for my 1200cc injectors from PTE. I bought a set from SIM, but apparently they are only for injectors through the 1000 size. PTE doesn't even show a 1200cc set, only 1600. I called them up and asked them about it, and they said that the 1600 seals work with their 1200 injectors. The problem is, I can't find anyone that sells the 1600 set, probably because PTE doesn't even sell the 1600's anymore. Hopefully someone with 1200 PTE injectors can give me some input, pretty frustrated about how much time ive put into trying to track this down. Thanks!
Someone chime in if I'm wrong but those are Delphi also and are u looking for the o ring that is at the top of the injector that sits in the rail or the o ring seal that sits in the head.. Either way I believe FIC injector seals work :thumb:
I'm looking for both. So you are saying that the replacement FIC orings and seats will work on my precision 1200s?
I have PTE 1200cc injectors and I just bought the seal kit from ExtremePsi. For just under $20 shipped they seem to fit, not sure if you need the upper black rubber spacer or not (not included in the kit), but I haven't installed them yet, just a test fit so far, hope this helps.
just be sure select "Precision" from the drop down
EXTREME PSI : Your #1 Source for In Stock Performance Parts
  • Wanted 2g ISO Rear Pass EDM Tail light
    Looking for only a passenger rear EDM tail light for my 2g. Please lmk if you have one lying...
    • Gabriel Pena
  • Wanted 4G63 ISO built short block
    Looking for either a 7 bolt split thrust or 6 bolt
    • Gabriel Pena
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale 2g 1996 Eagle Talon TSI AWD
    I have a 96 Eagle Talon AWD standard tranny for sale. The car still ran when I parked it. I had...
    • eli1977
  • For sale 2g 2g front strut shock cup. MR103156. New.
    Mitsubishi Oem # MR103156 front suspension strut cup. New. Message 702-741-6987.
