PTE injectors
A sport compact style honda? Most of the time Civic, preludes injectors would fit, depending on the year and engine... But more clarification on the injectors would make this easier. Did you ask the seller?
Also, do you have something to tune with like link? You'll need it.
You know if there High impedance or low?
Edit: If you remove the injector resistor pack and make up a plug to connect the power to all the injectors you could run High impedance but it wouldn't be beneficial.
Than if they fit, you should be good to go. With the supporting mods of course.
A Picture of them would help alot...
What do you mean by flush?
I myself,
Have used different smaller lower o-rings in the past with PTE injectors helps them fit better... .
