Prothane Install, HELP NEEDED!
Dapperz
35
Feb 23, 2016
Hot Springs, Arkansas
I have searched, both here and online, and can't seem to find an install instruction set for their urethane bushings. I've watched how to press the oem bushings out and replacement of oem bushings but can't find anything on the prothane ones. Do you install them simultaneously from both sides since they kind of "sandwich" together? Do you still use a bushing press? If anyone can provide any insight I would be much appreciated!
I have never had to use a press to put aftermarket bushings in and I did "sandwich" them in. But it would help to know which bushings you are replacing.
Sorry, I have the Porthane Total Kit so I would like to use all of the bushings included. Right now though I am working on the Upper and Lower Control Arm bushings.
