prosport gauges not working
greathuskie
2,666
4
Sep 10, 2002
Hollywood, Florida
ive tried everything to get these wired. there is 4 wires, green which is for the sender, orange which is the headlight/dimmer, black which is the ground and red which is the 12v ignition.
i had orange hooked up to green/white cord, the red wire hooked up the black/white under the steering wheel, black attached under the center console and green not hooked up. the gauges will not light turn on. i first tried to hook them up to the dimmer but that didnt work, then i tried normally, that didnt work either. can someone tell me what the deal with these is? ive been searching on here all night and cant find anything. anyone tell me exactly where and what color wires you hooked em up to so i can try it and see if it works?
right now i cant start my car, only turn it to acc.
Damn I forget where they all go at the moment. I installed my Prosport Tinted Boost Gauge like a month ago and it works fine. I'll try to give it a once over tomorrow and get back to you.
depending on where you tapped in for power you would need to turn the car on, not just to acc. if you can, take the gauge out and hook it directly to the battery. black to neg terminal, and red + green or white wire to the positive terminal and see if it turns on and what color the gauge glows.
I forget what color goes where but 2 wires from the sending unit go to the guage, one goes to switched power, one goes to ground, and i had one left over because i didnt have it change colors
I just installed my Prosport yesterday, I have it to where it is white during the day and amber when I turn the lights on. Everything was great until earlier today. Turned the lights on and the ####ing thing stayed white. Looked over all the wiring and it all checked out fine. The LED inside blew out....what a pos.
