Programing power locks
rixcidia
280
Dec 5, 2007
Somewhere in BC,
Hey guys so I'm trying to program my remote and Am unsuccessful in doing so when I put the key in my door I turn the lock I hear a relay making a noise but the doors power unlock and lock don't happen I have to unlock and lock manually , I tryed to follow the instructions for programming a 97 2g but puttin a jumper between pins 1 and 4 and ect and nothing happens anyone know why this is?
Rix.
Anyone run into this problem?? The remote I bought is a 3 button model GQ43VT6T I hope that's the correct one
Rix,
Thanks for the reply I actually just replaced those cause my other 2 were broken but still does not work, do the actual door panel it self have to be on?
Rix.
If I press my lock and unlock and I hear the locks trying to move but I does not what does this mean??
Rix.
When I push on the door panel it does it I can hear the actuator trying to move and same happens when I use the remote.
Rix
When the actuator doesn't work, it causes the same issue, But to make sure, check your Key sensors, if they are hooked up well and in good working conditions, then your actuators are bad.
When I bought my car, it came with both actuator broken, and I had to replace them, after that, I haven't have any problems.
By the way, when I had them broken, they used to do the same thing as your.
Yeah I just replaced my sensors and when I turn the key I hear the relay and doors trying to lock I have some replacement door actuators I got from s&m auto how are they to install in the doors?
Rix.
Hey guys so I installed the actuators and the drivers side works now but the passanger side is still faulty, I noticed when close the door the trigger don't touch to the bottom of the door is there a way to get it lined up proper? Cause the lights in the car still stays on.
Rix
I have a body kit on my car but I can't see that being an issue the door closes like normal from what I can see.
Rix.
