Problems with rebuild!!!!
Jbruiser21
Sep 10, 2009
Paragould, Arkansas
I just rebuilt my 4g63t and im having some issues. When I start the car it idles rough at 500 rpms then eventually dies. I have checked the timing many times and its perfect. Everything on the motor is brand new besides the throttle body and 02 sensors. What sensors could cause it to run like this? Or is there another reason why. Could not having the egr hooked up be the problem too?
Have you checked to see if you have any boost leaks?? My car had a similiar issue. Turned out to be 4 boost leaks 3 at the TB and 1 at the EGR. I would maybe start there. Is everything plugged in correctly? MAF is plugged too??
