problems after rebuild
Deven
Mar 10, 2014
myrtle creek, Oregon
Well Ive searched and didnt find what I need so heres my question.
I just fully rebuild my 96 eclipse gst and its runs great but after a test run I thought I heard a little bottom end noise so I pulled the oil pan and the rod caps and they are worn funny the middles of each rod bearing is worn (All shiny) I tested the clearance before I started it with plastigage and it it says im at about .045 mm witch is sapose to be in spec. I have arp studs in the rods and a brand new crank I dont have a stretch gauge but I fallowed arps instructions on torquing they say 38 lbs. Im just not sure where I went wrong should I try to run it more? Ive got a lot of money into this motor and dont want to destroy it.
The only thing I can think of is when I first started it it reved to about 3k rpms I turned it over a lot before starting it and used assembly lube on each bearing.
Well Im running just the ARP rod studs because thats all that was sapose to be torque to yield and I couldn't find stock replacements. nowhere said there was anything special needed. If the rods are out of round wouldn't I get bad clearance readings? and its the same on every rod.
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
