Idle problems after rebuild
turbodsm87
32
Aug 10, 2005
xenia, Ohio
so i just finnished rebuilding my motor and put it in. the only problem i have had other than a few oil leaks is the idle. it suges up and down and the car will hardly stay runnig unless you are on the throttle. I have adjusted the biss screw and i know the timming belt is correct. what else could be wrong!?:confused: could the camshaft postion senorr be out of time?? if it is how do i fix it??
I am having the same problem with my idle. I think the injectors on my car my be clogged for some reason.
Everyone I ask about the idle problem tells me it is an ignition problem or a fuel delivery problem.
I had similar proplem mine was a ripped vaccum line for the cruise control box check the rubber hoses good luck :thumb:
