Problems with engine cutting out
Kyle97turbo
47
Dec 15, 2005
Omaha, Nebraska
I have had this problem for a long time now. Whenever I am at cruising speed and just barely get into boost then let back off the car bucks like crazy and the rpms drop. It has absolutely NO boost leaks and the isc is fine. Could this possibly be the tps??
Please don't bump your posts.
Did you do an actual boost leak test? Or do you just THINK there are no boost leaks? How long did it take for the psi on your boost gauge to reach zero?
What kind of spark plugs and plug wires are you using? What gap? How old are they?
I actually just got done doing another boost leak test and there are none. It takes about a minute to taper down to 6 or 7 psi then it just holds there. The plugs are ngk 6's about 8 months old. I believe they were gapped at .028.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
