ECMlink Problem Timing Retard...
retard timing 2G
  • full
    Votes: 1 100.0%
  • full
    Votes: 1 100.0%
  • Total voters
Luciano Bernardo
Jun 29, 2017
Sao Paulo - BRAZIL, South America
Hi, Dear Friends
I'm 3 years old with this problem and nobody can find out the cause, I'm new here and if anyone can give an opinion, I appreciate it. In annex the LOG, it delays the point dratically when it should advance and then comes back ahead, generating leaps between 4 and 5K. I already changed 2 MDP sensor AEM 5 Bar because they told me it could be him.
I have Pistons Wiseco Forged, GSC Cams 268x268, ECMLink V3, Speed Density, AEM 5 Bar, Walbro 450 Rewired, GT3077R Kynugawa, Exhaust 3´, Engine head 1G, Valves + 1,00mm.
Thanks;
1). Any boost, vac, or exhaust leaks? Boost leak tested 5psi above your max boost with no leaks?
Yes, with 30PSI, OK
2). Verified mechanical timing?
Yes
3). Verified base timing?
Yes
4). Ignition system
COP or Stock Coil: Stock with CAS Black and MSD
Wire brand and Age: MSD 8.8 New
Spark Plug brand, type and Gap: Iridium BKR7EIX GAP 0.28
5). Motor health (Compression Test)
Cylinder 1:OK
Cylinder 2:OK
Cylinder 3:OK
Cylinder 4:OK
6). Performed basic throttle body adjustments?
Idle Switch: New OEM
Throttle Cable:New OEM
TPS:New OEM 0,63V
BISS:OK
Throttle S90 70mm
7). Compression ratio
10,5 X 1
8). Any known bad sensors or brittle wiring?
News Sensor OEM and wiring new
9). Any DTC/CEL codes?
No DTC
10). Electrical system
Car off (not running):
Car running:
11). Base fuel pressure and injector values
Base Fuel Pressure: 43,5 PSi
Injector Size (cc/min): FIC1100cc High Z New
12). Properly calibrated and configured wideband sensor
Sensor Brand: LSU 4.9 PLX
Calibration Date: NEW Install
13). Type of fuel
Type: GAS 93
Percent of Ethanol:25%
14). Watched ECMlink how-to videos?
yes
