priming oil pump
packinkimber45
378
3
May 26, 2006
Boise, Idaho
Hello everyone, I will be timing my car here soon and priming the oil pump before I install the tbelt and time it. I was wondering... I'm sure in order for me to prime the oil pump my 90 style ofh connections to the oil cooler will need to be hooked up to the cooler or somehow have them sealed in order to prime the motor. I want to see what people are doing to prime the oil pump with the connections on the ofh not connected. Is there a way to do it w/o hooking up those connections? Im talking about the two blue connections in the pic below. Thanks in advance.
If your hose has -AN fittings on both sides just connect both ends of one to it. Im not sure where the -AN block off nuts can be found.
I had to prime mine not too lone ago. Off course all the belts were off. I found that a couple of the tension mounting bolt holes are tapped into the oil gally. Like the balance shaft tentioner bolt hole. I think there was another one too. Anyway, When I put the drill motor to the pump shaft and it started to build pressure. Oil started coming out of them.(bolt holes) I put sealer on them when I put my belts on. It was only one source of my leaks. Hey, It's a 4G63.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
