2G Preparing to install Fp 68
Jacolu3
638
131
Jan 31, 2015
Lake Grove, New York
So first I'll give a little back story.
I have a 97 gsx with stock turbo. I purchased a built motor and I am assembling everything on an engine stand to make my life easier.
I purchased a Fp 68 turbo with new gaskets and the oil feed line.
The motor I purchased has all the water lines permanently plugged with maybe jb weld or something that I can't remove.
So I'm looking to put all new coolant lines on this motor that connect to this turbo.
Do I just buy all oem lines and fittings that connect to the turbo or is there a kit that someone makes so I don't have to piece together all the water lines for the turbo?
Thanks
Brian
So I'm guessing I'll need a new water pipe but what about the banjo line?
I second buying the AN fittings that with thread right in to your turbo and buying 3/8 hose to run where ever you plan to route your water lines. I'm installing the 76HTA and running the lines from the thermostat housing to the water pipe(Where you took a pic). Very easy and clean using the AN fittings. Those fixed lines can be a pain to work with compared to just running the rubber hose. If your worried about heat, just put a heat sleeve over the hose.
