prelude hazard light help
97-gst
1,234
May 16, 2010
Radford, Virginia
On my girlfriends 1987 honda prelude i went to turn on her harzard lights and they worked but when i went to turn them off they just wouldnt turn off... i tried and tried then eventually i ended up having to take out the fuse for the hazard lights so now she has no signal lights... any ideas or suggestions on what i can do because as soon as i plug her fuse back in the hazard lights are on? thanks
It's most likely a problem in the switch. I'm sure you tried, but with the switch plugged in try to work it by pushing the button in and out even tapping it kind of hard. This will hopefully free up the contacts in the switch and get it to work again, or at least turn off. If you can get it to turn off like that then you know it's your switch for sure and you can replace it. Good luck
