Pre-emptive maintenance suggestions?
Arrow_Runner
199
Jul 17, 2005
Milford(Cincy), Ohio
Can anyone suggest some reliable/inexpensive brands and locations to order these parts from?
I know of a few local shops where I can price the items, but there's gotta be some better/cheaper aftermarket sites out there.
Water pump
Oil pump
Harmonic Balancer
Belts
Anything else I forgot?
Everytime I look for stuff it ends up being 1g Turbo or 2g performance parts...
Thanks for the link.
And I know they need to be OEM, but different brands make OEM specification parts, right? Like Felpro or whatever.
You can get away with a non oem waterpump and timing belt. For the timing belt everyone seems to have had good luck with the "gaterback" brand. I personally would only go oem for the oilpump. I just dont trust anyone else, heard some pretty bad horror stories. Go with oem or 'gates' brand for the belts, as everything else seems to skweel like a mofo. Harmonic balancer i would just go to a local junkyard and pick up an extra one.
why do you need an oil pump?? you having low oil pressure?
oil pump isn't really a maintenance item, usually people change it when they rebuild the engine.
other maintenance items would be
fuel filter
all the fluid on the car
Well, I've already replaced the thermostat and timing belt. I've seen it's been recommended that I change the other belts and the water pump and the harmonic balancer. I saw the oil pump recomended in a 1Gnt to Turbo sticky.
This car is most likely going to spend the rest of its life as a dd for my wife, so my main goal is to fix everything so it doesn't break down on her. The second goal is that I get some more experience with pulling the engine because I do plan on getting a TSI/GST for myself someday:shhh:
I know I could get a defective part, or murphy's law could just take place, but I want to get this car in the condition where I hopefully won't have to touch the belt side of the engine for another 60k.
One of the things I was hoping to get out of this thread is an alternative source of parts from the local autoZ and advance a p.
Really the only parts i wont buy from autozone/advance are the ones stated by myself above. Almost every other part i wouldnt have any issue with buying from the local parts store, but those are just too critical for me to chance on a possible failure due to faulty manufacturing. I think most people will agree with me on the parts i would get only from the dealer. Good luck with the car, they can be very reliable if you do as your trying and keep up with the maintanence
