power windows don't work - 1g. everything else does.
slowgsr
862
10
Dec 17, 2007
hamilton, ON, Canada
Hey. its a 1990 1g talon awd. I did some modifications to the interior harness, everything works that I wanted to. Signals/tails/headlights, horn, power mirror/lock, brake lights etc. Its a street/race car.
Anyways. The damn power windows don't work, im thinking Im missing a relay or something simple.
The problem is, I can't find any diagrams on where the relay is for the power windows, or the circuitry. So im just looking for some info on the power window system in a 1g. Just so I can troubleshoot it and figure out what I did.
Thanks guys.
Try if the passenger side switch works? Maybe the driverside switch is bad. I believe the relays are in the fusebox. Also hows the fuses look? Check em all.
Thanks, neither drivers or passengers work. I'm really looking for specifics on the wiring system for the power windows.
As I said I modifed the harness drastically and really need exact locations, and diagrams to make it easier to troubleshoot.
I'm working on the same type of situation minus the wiring being modified. The dash was removed and the heater core and assembly was removed with a few other things. The dash is back in and now the windows don't work but everything else does. The fuses and relays all work so it appears to be something disconnected possibly.
check the fuse in the engine bay, could be a bad switch, i always pick up extras when i can at the upull it, bad ground. retrace everything mine was the fuse, and the wiring was frayed on the switch.
