Power steering pump leaking on to my Alt..
nfernotalon
1,726
4
Aug 30, 2007
Greeley, Colorado
My power steering pump keeps killing my alternator because of the fluid dripping on to it. Is there o rings or gaskets or something that i need to replace?? Or do i need a new pump? thanks:notgood:
don't forget to cover the alt shen you change it cause it will get messy....very very messy......
Black silicone is NOT the way to go - Cover the Alt because yes you will make a helluva mess - Get a few assorted VITON O Ring Kits from any good Auto Part Store & swap out EVERY O Ring on EVERY fitting on there - Including the TEENY internal one between the ECU Switch Terminal Post & it's Fitting - & yes P/S Fluid kills Voltage Regulators which kills ECU's - Personally I took this opportunity to do a P/S Flush went back with Synthetic P/S Fluid.
