Power Steering Hose question
bNasty
669
5
Jan 15, 2009
Chantilly, Virginia
Alright sorry if this is kind of a newb question but here goes. So I have a power steering leak and its not coming from any of the high pressure lines from the pump but its coming from the line under the rack, that goes into the rack. Its a small line about a foot long that goes from the drivers side of the rack to the passengers. Well something is wrong with the fitting or the line because the line is loose while the fitting is tight causing a leak.
Anyway my question is would i be able to get a new fitting a line then patch it with the old line with some fuel hose and clamps? Or is the system under too much pressure?
its a line similar to this but this is off a 1g
