Generation1JeY
- 547
- 0
- Aug 5, 2004
San Diego,
California
Hey, i was wondering how many of you have done this and if you have run into any problems because of it. i have seen on a lot of dsms both 1g and 2g people have done this when they get poly motor mounts. To be more clear the timing belt motor mount bracket that is attached to the motor mount itself, you know how it attaches to both sides of the block since it is a twist mount, i have seen a lot of engine bays where people simply cut the piece of the bracket that extends forward and goes over the studs. So basically it just has the two bolts mounting it to the block and then the motor mount. Also you take the big bracket that bolts to the front of the block with four bolts. The bracket that holds the power steering bracket on and you cut that or just simply remove it completely along with the power steering.
That is my next question. I'm contemplating removing my power steering, i just want to hear from people who have removed their power steering. If i removed it i would be getting a manual steering rack, i found one close by at a junkyard, it could just be out of any 1g dsm with manual steering correct? does it matter if the motor is 1.8 or 2.0 or turbo or not?
So to sum it up, the motor mount bracket cutting, the advice on power steering removal from people with experience with it out. Just if it is not a complete pain in the ass to drive. And then the manual steering rack that would be compatible with my car. Its a 91 eclipse gs (fwd turbo)
Thanks for any help.
. As for the cast iron motor mount bracket, i went to town on this thing, I chopped the bottom set of bolt holes out so now it only bolts to the block using the two upper bolts, then i removed the top piece where the two studs are for the motor mount, then i took out the edge that interferes with the exhaust manifold and headstud installation, and last but not least i evened out the side of the bracket where there is a stud where that one piece connects the two brackets. I wish i could post pictures, but basically the bracket is no bigger than it needs to be, i'm still using all three bolts to mount the power-steering bracket, and thats basically the only reason why that bracket is still there. Otherwise i just wouldn't even have it. I just decided that as a daily i'm sure i would hate to not have my power steering.
