power locks not working....need some help!!
eclipse0508
270
Nov 17, 2003
Plattsburgh, New York
hey everyone
on my 95 eclipse gs, my power locks aren't working at all. i check the fuse and its okay. also, when i hit the lock button, i dont hear anything, not even a sound. Has anyone had this problem? Any help would be appreciated, since I want to install my new alarm system, but I need the locks working first.
I tried searching, but all the searches i found indicated noises when pushing the button, and im not getting any sound.
thanks guys....
I'd check wiring at the switches..could be loose plug. I know the little pin that hold the switch in place broke on mine and came loose...had the same symptoms. Secured the plug and no problems since.
Another thing to look for could be broken wires either at the switches or at the kick panel where the iring comes through. Good fuses indicate just that, good fuses, it won't tell you if a wire is broken.
Let me know if you need more help.
