Power Locks, Interior Lights, and Stereo Not Working???
TSI95FWD
Dec 8, 2005
Westmont, Illinois
I was messing around with the wire on my halo's from my projector headlights and I try wiring the halos to a fuse in the passenger compartment box and I kept blowing fuses so I decided to go back to the original way it was with a switch and everything. Got it back to normal then my radio wouldnt work and then I realized my locks wouldnt work either. As I was testing things out neither did my interior lights or my power mirrors. I have checked every fuse and they are fine. Is there another fuse somewhere that I dont know where or could it be a bigger problem? I have an aftermarket stereo if that helps at all. Any help would be appreciated greatly I am going insane here. Thanks
There is a "reset button" on the fuse box in the inside of the car, I don't know about the outside box.
Are you talkin about the fusible links inside the fuse box under the hood??? I checked those already if they are the same thing im thinking of
