Power Goal Req
Lyle Corpse
47
Nov 12, 2014
Munster, Indiana
So i have a 98 GSX. I want to make about 300 to the wheels and currently all I have stock piled parts wise is
  • Evo 3 16g (genuine MHI)
  • VRSF Fmic
  • Walbro 400lph fuel pump
  • Innovate Wideband
  • Evo 9 injectors
I know I still need DSMlink and a Fuel Pressure regulator but I was wondering if there was anything else I needed or if I should be pretty set. I do have ARP headstuds installed as well as a newer headgasket installed along with Gates racing belts
You are on the right track. For reference I made 306 to the wheels on a dyno pack dyno with the following in my 99 GSX back in the day.
Stock 7-bolt engine with stock cams
1G Throttle body with Intake manifold ported to match
MHI B16G
VRSF Front Mount
Walbro 190lph
Denso 720cc injectors
ECMlink
RRE 2.5-3" Downpipe, no cat, and full 3" exhaust
A set of mild aftermarket cams would have helped my setup and will probably help yours as well.
MHI B16G
VRSF Front Mount
Walbro 190lph
ECMlink
alright sweet and thanks for the guidance! Do you think running a stock throttle and manifold would be alright?
I don't think it will matter a whole lot, especially if you are still running stock cams. But the 2G throttle body is 52mm diameter and the 1G is 60mm diameter so it is a pretty good low cost modification to do to the car. Here is a link to the RRE page with information on the swap.
http://www.roadraceengineering.com/2gtbswap.htm
you're right, yeah i'll totally look into it then!Thank you!
Don't forget a full exhaust and then maybe an upgrade clutch.
oh yeah, that'll probably be a good thing to not forget to do. Last thing I wanna do is finally be ready for the summer just to have to drop the trans and replace it XD
