Power door lock problem
DSMchouinard7
Aug 22, 2012
Rock Falls, Illinois
Alright, I bought a 95 eclipse gs and the passenger door lock never worked, i thought, the other day I noticed I went to go lock my doors and for once it worked! It worked for like one day and that was it. I checked the harnesses behind the door panel and they all looked okay, I was wondering if it was the relay was going bad. You can hear the click from the relay,but the drivers side usually just works is there a way to diagnose this. I am open to ideas. And where is the relay at if someone can give a picture that would be awesome! Thank you
Pull your door panel off and trace the wires to the door lock accuator. Test to see if it is actually getting power. If it is, then you know its the accuator seizing up. If there is no power, start tracing wires to see where you are losing it. Usually the best idea is to start at the problem and work your way back.
