Power Door lock actuator
JMoney
Jan 27, 2013
SLC, Utah
Hey guys, I'm working on my door locks and found the fuse was missing, when I put one in it buzzes constantly. I'm also missing the wire connector from the passenger side lock to the actuator. Is the buzzing form the incomplete circuit or a bound up actuator? Any thoughts? :confused:
Thanks
Is it buzzing like the door is open, if so check your door sensor at the bottom of the door rail.
I'll check that, but it does it even with the ignition off. I,ve also pushed the door lock button while it's buzzing and nothing.
I just tried it again and the noise is way too loud and obnoxious to be the door open buzz.
Lol i don't know I unpluged mine because it was so loud and annoying, but I know most of the door buttons get stuck. But if its not that, them someone else will need to chime in.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
