Power cut-out after BOV install
YJ_90
Jan 2, 2004
Forest Grove, Oregon
I have a '97 Eclipse, I just installed an upper intercooler pipe, and a Apex bov, beforehand I was running the stock pipe with the HKS BOV, since I installed the new pipe I am getting a nasty cut-off at 4500 rpm. It doesn't at full open throttle but when I am in a steady acceleration. Does anyone have an idea as to what is causing this?
Thanks in advance,
Jake
Yes I do have the vacuum lined hooked up, I am not sure if it has an adjusting screw it was a hand me down so I don't know a whole lot about the situation. It came straight off a '94 talon that was running 12's. I'll have to check and see if it is adjusted wrong, is there anything else? I didn't mention this earlier, not sure if it matters but, I have a short ram intake also, but am still running the stock exhaust, a friend mentioned something about maybe getting a boost spike?
Thanks again,
Jake
