Car wants to cut out after...
Incredible_Culp
164
Apr 27, 2012
Norman, Oklahoma
I installed 550cc with the 2g MAS..
huge difference in performance :D
but say at a stop light, or basically at low rpms, when i try and give it gas, it stutters and and wants to cut out it feels like..
i have to rev it higher for a smoother "take off.."
im untuned.. i think that might be the culprit.. but idk..
any suggestions?
91 eagle talon, big 16g.. was running stock 450 and intake.. installed the 550 and 2g mas last night.. other than that, its basically stock.. im also dumped, but im getting the rest of the exhaust back on in about 40 mintutes
check for boost/vacuum leaks. its not a good idea to run 550s on a stock tune but it should be running rich not wanting to cut out on you.
550s and 2g maf sensor have been used together for years on 1gs, you also have a lightened flywheel. It's not out of the ordinary to have to give it a little gas to take off with one.
i dont think you understand LOL... ill have to come by and show.. i can put the pedal to the medal -- so to speak -- and it want launch sometimes from first gear.. i hear the turbo spool and everything.. the rpms go up and down back and forth
sometimes the car runs fine.. then out the blue, it starts acting up again..
i re did everything tonight.. went for a drive, and it was better.. it did *as stated above* only one time..
i might've fixed the problem when i re did everything .. i probably didnt tighten bolts down all the way, maybe didnt plug something in.. etc. but like i said, it acted a lot better.. ill know more tomorrow when i drive for longer periods of time
